poIResultMathCtrl GetOperatorList
Gets a list of operators for a particular library.
rmath_handle GetOperatorList lib_name
HyperView Tcl Query
This command returns a list of result module operators corresponding to a library.
lib_name
The name of the result module library.
To get the list of operators for a particular result math library:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
set mid [client_handle AddResultMathAnalysis "c:/samples/bumper/d3plot" "c:/samples/bumper/d3plot"]
client_handle GetModelHandle model_handle $mid
model_handle GetResultCtrlHandle result_handle
result_handle GetResultMathCtrlHandle rmath_handle
set lib_list [rmath_handle GetLibraryList]
foreach lib $lib_list {
    set oper_list [rmath_handle GetOperatorList $lib]
hwi CloseStack
Returns an empty list if an error occurs.
