poIPostManager SetMemoryWarningEnabled
Enable or disables the memory usage warning.
poIPostManager_handle SetMemoryWarningEnabled enabled
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, enables or disables the memory usage warning feature, which will warn you when system memory reaches a certain threshold.
enabled
True to enable the memory usage warning feature, false to disable this feature.
To enable the memory usage warning feature:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr SetMemoryWarningEnabled true
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
