poIPostManager SetMaximumMemoryUsage
Sets the maximum percentage of physical memory that the post client should use.
poIPostManager_handle SetMaximumMemoryUsage percentage
HyperView Tcl Modify
This command sets the maximum percentage of physical memory that the post client should use.
- percentage
 - A value between 20 and 100.
Returns the percentage actually set (values below 20% are not permitted).
