poIPostManager GetMemoryWarningThreshold
Gets the memory warning threshold value.
poIPostManager_handle GetMemoryWarningThreshold
HyperView Tcl Query
This command, valid only in HyperView - MultiCore profile, returns the current memory warning threshold value. This value is a percentage from 0-100 which represents a percentage of the total system memory. If the total system memory exceeds this threshold and the memory warning feature is enabled, a warning will trigger.
To get the current memory warning threshold:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr GetMemoryWarningThreshold
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
