poIPostManager GetGlobalPropertyType
Gets the global property type.
poIPostManager_handle GetGlobalPropertyType property
HyperView Tcl Query
This command returns the type of the global property.
property
The name of the available global property.
To get the type of the global property:
hwi OpenStack
session_handle GetClientManagerHandle manager_handle Animation;
manager_handle GetGlobalPropertyList
manager_handle GetGlobalPropertyType "Convert 2nd order elements to 1st order elements"
hwi CloseStack
This command returns empty string, if there is no option list.
