poIPostManager GetMemoryWarningEnabled
Query whether the memory usage warning is enabled.
poIPostManager_handle GetMemoryWarningEnabled
HyperView Tcl Query
This command, valid only in HyperView - MultiCore profile, returns true if the memory usage warning is enabled and false if it is not enabled.
To query if HyperView is loading vector data:
hwi OpenStack
hwi GetSessionHandle sess
sess GetClientManagerHandle mgr animation
mgr GetMemoryWarningEnabled
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
