poIScalarDefine SetAverageFactor
Sets the nodal variation factor. Specify the threshold variation level above which nodal averaging should not be carried out.
poIScalarDefine_handle SetAverageFactor f
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the nodal variation factor, which specifies the level above which nodal averaging should not be carried out.
Note: The result definition can only be modified if it is not cached.
f
The threshold level between 0.0 and 100.0.
To set the average factor for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetAverageFactor 35.0
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
