poIScalarDefine SetEnvelopeTracingEntity
Sets the envelope tracing entity.
poIScalarDefine_handle SetEnvelopeTracingEntity entity
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the envelope tracing entity for the result definition.
Note: The result definition can only be modified if it is not cached.
entity
The envelope tracing entity value. This value must be one of the following: "none", "simulation" or "subcase"
To set the envelope tracing entity for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetEnvelopeTracingEntity subcase
hwi CloseStack
Returns an error code if there was an error setting the envelope tracing entity and sets error condition on the session handle. See session_handle GetError.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
