poIScalarDefine GetIsMultipleLayers
Gets the multiple layers state.
poIScalarDefine_handle GetIsMultipleLayers
HyperView Tcl Query
This command, valid only in HyperView - MultiCore profile, returns true if multiple layers is enabled for this result definition, false otherwise. This will be true if the layer is Top/Bottom for this result.
To check if a result definition has multiple layers enabled:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine GetIsMultipleLayers
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
