poIScalarDefine SetMultipleLayers
Sets the multiple layers state.
poIScalarDefine_handle SetMultipleLayers mlayer
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the multiple layers state for the result definition. This state should be set if using the Top/Bottom layer in the result.
Note: The result definition can only be modified if it is not cached.
malyer
True to enable multiple layers, false otherwise.
To set the multiple layers state for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetIsMultipleLayers true
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
