poIScalarDefine SetIgnoreFlippedNormal
Sets the ignore flipped normals enable state.
poIScalarDefine_handle SetIgnoreFlippedNormal enable
HyperView Tcl Modify
This command, valid only in HyperView - MultiCore profile, sets the ignore normals enable state for the result definition.
Note: The result definition can only be modified if it is not cached.
enable
True to enable ignore flipped normals, false otherwise.
To set the ignore flipped normal state for a result definition:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle client
client GetResultHandle sdefine 4 scalar
sdefine SetIgnoreFlippedNormal true
hwi CloseStack
None.
See the HyperView - MultiCore APIs topic for additional information regarding the various Tcl/Tk commands that have been added for this workflow.
