poITracingCtrl AddStaticCurveToPlot
Adds a static tracing curve for a single node over frames to the selected window.
poITracingCtrl_handle AddStaticCurveToPlot item_idx yAxis plotwin
HyperView Tcl Modify
This command adds a static tracing curve for a selected index node in the Tracing panel to the selected window.
item_idx
The node index in the list box.
yAxis
Coordinate: "X", "Y", "Z"
plotwin
The plotwindow handle.
Returns 0 if successful, otherwise an error code.
