poITracingCtrl SetCurveByComponent
Defines the Tracing plot 'Curve by Component' option.
poITracingCtrl_handle SetCurveByComponent state
HyperView Tcl Modify
This command defines the 'Curve by Component' option of a tracing curve. This only effective when a single curve is set to true.
state
true: plot one curve per component for each frame.
false: plot one curve for all components for each frame.
Returns 0 if successful, otherwise an error code.
