poITracingCtrl RemoveEntity
Removes an entity from the tracing control.
poITracingCtrl_handle RemoveEntity entity_id_str
Tcl Modify
This command removes an entity from the tracing control.
entity_id_str
The entity ID or the pool entity ID.
Returns 0 if successful, otherwise an error code.
