poITracingCtrl SetColorByComponent
Defines the Tracing plot 'Color by Component' option.
poITracingCtrl_handle SetColorByComponent state
HyperView Tcl Modify
This command defines the 'Color by Component' option of a tracing curve. This only effective when a single curve is set to true and 'Curve by Component' is set to true.
state
true: curves of a component for each frame are all drawn in the component color in a graph.
false: curves' color will be assigned by default in a graph.
Returns 0 if successful, otherwise an error code.
