poITracingCtrl AddStaticCurveToWindow
Adds a static tracing curve for a single node over frames to the preview window.
poITracingCtrl_handle AddStaticCurveToWindow item_idx yAxis page_area_id
HyperView Tcl Modify
This command adds a static tracing curve for a selected index node in the Tracing panel to the preview window.
- item_idx
- The node index in the list box.
- yAxis
- Coordinate: "X", "Y", "Z"
- plotwin
- The preview window ID.
Returns 0 if successful, otherwise an error code.
