poIContourCtrl CopyToClipBoard
Copies contour data to the clipboard.
poIContourCtrl_handle CopyToClipBoard
HyperView Tcl Query
This command copies contour data to the clipboard.
To copy data to the clipboard:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
contour_handle CopyToClipBoard
hwi CloseStack
Error
Returns 0 if successful, otherwise an error code.
