poIContourCtrl SetValueFilter
Sets contour value filter value.
contour_handle SetValueFilter filter
HyperView Tcl Modify
This command sets the value filter for the contour.
filter
The filter string to be applied. Examples of the valid filter strings are: “>= 10.123”, “<= 10.123”, and “Range 10.123 100.456”.
To set the value filter string for a contour:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetContourCtrlHandle contour_handle
# Set the value filter
contour_handle SetValueFilter ">= 100.666"
hwi CloseStack
Error
Returns an empty string if the filter string is not in the standard format. The valid formats are: “>= 10.123”, “<= 10.123”, and “Range 10.123 100.456”.
