poIContourCtrl SetMultipleLayerList
Sets the Top/Bottom layer.
poIContourCtrl_handle SetMultipleLayeList std::string
HyperView Tcl Modify
This command sets the Top and Bottom layer. The Top and Bottom layer are taken in a form of a single string with delimiters. The Delimiters can be “,;|”.
- std::string
- The Top/Bottom layer information is set in the form of a string with delimiters.
hwi OpenStack
hwi GetActiveClientHandle p
p GetModelHandle m [p GetActiveModel]
m GetResultCtrlHandle r
r GetContourCtrlHandle c
c SetIfMultipleLayer true
c SetMultipleLayerList "Z1;Z2"
Error
Returns HW_Success if successful.
