poIContourCtrl GetResultSystem
Gets the result system ID.
poIContourCtrl_handle GetResultSystem
HyperView Tcl Query
This command retrieves the result system ID.
Error
Returns the system ID.
Copies contour data to the clipboard.
Gets the averaging state for element results.
Gets the method by which elemental results are averaged to nodes.
Gets the list of possible averaging modes.
Gets the state of the average across parts.
Gets the current color mode.
Gets the contour corner data enabled state.
Gets the current plot style.
Gets the current data component for the given dimension.
Gets the current contour data type.
Gets the dimension state.
Gets the discrete color mode.
Gets the pool state, either enabled or disabled.
Gets the auto load/unload contour data state.
Gets the angle set for the feature angle average.
Gets the state of the feature angle average.
Gets the state of the "Ignore Flipped Normal" option set for the feature angle average.
Gets the interpolate color mode.
Gets the current layer's label.
Gets the legend control object for contouring.
Gets the layer list. Returns both Top/Bottom as multiple layers.
Retrieves the multiplication factor for the current contoured data type.
Gets the current contour offset value (lowest scale in the legend).
Gets a list of all the contour plot styles stored in the contour controller.
Gets the current shell layer label.
Gets the state of the "Show Midside Node Results" option for the contour control.
Gets the maximum threshold value of the contour.
Gets the threshold maximum enable state (true/false).
Gets the minimum threshold value of the contour.
Gets the threshold minimum enable state (true/false).
Gets a list of valid systems for the specified data type and components.
Gets the contour value filter string.
Gets the state of the contour value filter.
Gets the list of values associated with a node or element selection set.
Checks to see if the Top/Bottom mode is enabled in the contour controller.
Removes a plot style with the specified name.
Renames an existing/old plot style with a new name.
Resets the contour controller settings with a memorized plot style.
Captures the current contour controller settings and saves it with the given name.
Sets the averaging state for element results.
Sets the valid range for the nodal variation factor.
Sets the method by which elemental results are averaged to nodes.
Sets the state of the average across parts.
Sets the current color mode.
Enables contouring node on element data.
Sets the current plot style.
Sets the data component for a given component.
Sets the data type for the contour control.
Sets the dimension state; enabled or disabled.
Sets the discrete color mode for node-based coloring.
Sets the dimension state, either enabled or disabled.
Sets the auto load/unload contour data state.
Sets the angle for the feature angle average.
Sets the state of the feature angle average.
Sets the Top/Bottom mode in the contour controller.
Sets the Top/Bottom layer.
Sets the state of the "Ignore Flipped Normal" option for the feature angle average.
Sets the interpolate color mode for Interpolation/Modal animation mode.
Sets the current layer label.
Sets a multiplication factor for the current contoured data type.
Sets the offset value of the contour.
Sets the result system ID.
Sets the selected entities to be used by the contour control.
Sets the current shell layer. The scalar storage within HyperView can accept a shell layer or a derived quantity of all shell layers (max, min, or extreme).
Sets the state of the "Show Midside Node Results" option for the contour control.
Sets the maximum threshold value of a contour.
Sets the threshold maximum enable state value of a contour (true/false).
Sets the minimum threshold value of a contour.
Sets the threshold minimum enable state value of a contour (true/false).
Sets contour value filter value.
Sets the state of the contour value filter.
ON THIS PAGE
HyperView Tcl Query
ON THIS PAGE
