poIContourCtrl SetCornerDataEnabled
Enables contouring node on element data.
poIContourCtrl_handle SetCornerDataEnabled enable
HyperView Tcl Modify
This command enables contouring node on element data.
Note: This state is valid only if the data binding is node-on-element.
enable
Set to true to enable corner data processing, or false to average corner data to the element centroid.
Error
Returns 0 if successful, otherwise an error code.
