poIContourCtrl SetLayer
Sets the current layer label.
poIContourCtrl_handle SetLayer layer
HyperView Tcl Modify
This command sets the current layer label. For this multiple layer support, the string name passed should be “Top/Bottom”. If not, multiple layer will be disabled and ends up setting the layer name which is being passed.
- layer
- The shell layer label or one of the following derived types:
- max
- Stores the maximum value of all layers.
- min
- Stores the minimum value of all layers.
- extreme
- Stores the maximum absolute value or all layers.
- sum
- Stores the (scalar) sum of all values among the layers for each entity.
- average
- Stores the (scalar) average value among the layers which contain data for each entity.
- range
- Stores the difference between the maximum and minimum values among the layers for each entity.
- maxlayer
- Stores the layer number (instead of the actual value) which contributed to the maximum value for each entity.
- minlayer
- Stores the layer number (instead of the actual value) which contributed to the minimum value for each entity.
- extremelayer
- Stores the layer number (instead of the actual value) which contributed to the maximum values for each entity.
Error
Returns HW_Success.
