poIModel GetFailureTimeList
Gets the failure time list with information of element ID, time frame, and time value.
poIModel_handle GetFailureTimeList elemtypelist
HyperView Tcl Query
This command retrieves the failure time list in the form of {element id, time frame, time value}.
- elemtypelist
- An element configuration list, for example "quad4 hex8" or "104, 208". Default is all element types.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# Failure list for all element types
set failurelist [model_handle GetFailureTimeList]
#failure list for quad and hex type elements
set failurelist [model_handle GetFailureTimeList "quad4 hex8"]
hwi CloseStack
Returns an empty string if there is an error.
