poIModel GetPolygonMode
Gets the component's polygon mode. If this is an assembly, ALL child parts must have the same polygon mode set, otherwise the returned mode will be "none".
poIModel_handle GetPolygonMode
HyperView Tcl Query
This command returns the component's polygon mode (transparent, opaque, or wireframe). If this is an assembly, ALL child parts must have the same polygon mode set, otherwise the returned mode will be "none".
None.
