poIModel GetUserDefinedSystemHandle
Gets a handle for the user-defined system as specified by the ID string.
model_handle GetUserDefinedSystemHandle sys_handle id_str
HyperView Tcl Query
This command returns a handle for the user-defined system only, and cannot be used to return the handle of the regular system.
- sys_handle
- The name for the system handle.
- id_str
- The ID string for which the handle has to be obtained.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
# id string in the form of system pool name and id
model_handle GetUserDefinedSystemHandle sys_handle "System 25"
hwi CloseStack
Returns a non-zero value upon failure.
