poIModel RemoveUserDefinedSystem
Removes a user-defined system from the current model.
model_handle RemoveUserDefinedSystem id_str
HyperView Tcl Modify
This command removes a coordinate system from the current model. Only user-defined systems can be deleted using this command. Systems that are part of the input deck cannot be deleted.
- id_str
 - The ID of the user-defined system.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set id_str  [model_handle AddUserDefinedSystem rectangular]
model_handle RemoveUserDefinedSytem "$id_str"
hwi CloseStackErrors
Returns a non-zero value upon failure.
