poIModel GetResultReaderPropertyList
Returns the reader options which were used to read the result data.
model_handle GetResultReaderPropertyList
HyperView Tcl Query
This command returns the user defined reader options which were set to read in the result file. For example, while reading in an Abaqus result file using the Abaqus result reader, the “ALTAIR_ODB_ELEMDATATYPES” option could be set to “BOTH” or “EXTRAPOLATE”. In this case, the command returns the name value pairs of the reader options as a flat list.
Note: This command does not return the name value pairs as a list of lists.
Context
To retrieve the model reader properties:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
set reader_options [model_handle GetResultReaderPropertyList]
hwi CloseStack
This command returns null if no reader option was used for that particular model. Some model readers do not have reader properties defined.
