poIModel SetMaterial
Sets the component material index. Calling this command on an assembly has no affect.
poIModel_handle SetMaterial id
HyperView Tcl Modify
This command sets the component material index. Calling this command on an assembly has no affect.
id
The material ID to assign to this component.
Returns 0 if successful, otherwise an error code.
