Browsers provide a structured view of model data, which you can use to review, modify, create, and manage
the contents of a model. In addition to visualization, browsers offer features like search, filtering, and sorting,
which enhance your ability to navigate and interact with the model data.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Tools and workflows that are dedicated to rapidly creating new parts for specific use cases, or amending existing
parts. The current capabilities are focused on stiffening parts.
Use PhysicsAI to build fast predictive models from CAE data. PhysicsAI can be trained on data with any physics or
remeshing and without design variables.
Explore, organize and manage your personal data, collaborate in teams, and connect to other data sources, such as
corporate PLM systems to access CAD data or publish simulation data.
Use the Acoustics tool to create 0D/1D acoustic elements.
An acoustic element is an element created in a space between two nodes/single node of
a model where acoustic properties are desired. Acoustic can translate to available
types depending on selected solver interface.
From the 1D ribbon, select the Acoustics
0D or Acoustics 1D tool.
Define the element.
Option
Action
Select an element type.
Linear 1D
Create one-dimensional elements based on a projection of Elems A to
Elems B.
Elems A
Select the elements where you want the elements to begin.
Restriction: Only available when the Linear
1D check box is selected.
Elems B
Select the elements where you want the elements to end.
Density A-B
Specify the number of acoustic elements you want created between
each of the selected elements.
when the Linear 1D check box is
selected.
Node A
Select the first end of the acoustic element.
Node B
Select the second end of the acoustic element.
Property
Select a property to assign to new and existing acoustic
elements.
Click Create.
Update Acoustic Elements
Use the Entity Editor to update acoustic elements for the
desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for
the solver.
