Create Joint Elements
Use the Joints tool to create joint connection elements.
Joint elements are used to create connection required to define kinetic-kinematic motion between nodes.
Update Joint Elements
Use the Entity Editor to update joint elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
