Create Contact Elements
Use the Contacts tool to create 1D/0D contact elements.
Typically contact elements are used to define surfaces or targets between two interacting bodies.
The nodes for a contact element must share the nodes of the underlying line, surface, or solid elements.
Update Contact Elements
Use the Entity Editor to update contact elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
