Create Bond Elements
Use the Bonds tool to create 0D/1D bond elements.
A bond element is an element created in a space between two nodes/single node of a model where bond properties are desired.
Update Bond Elements
Use the Entity Editor to update bond elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
