Create Gasket Elements
Use the Gaskets tool to create 0D/1D gasket sealing elements.
Gasket elements are typically used in implicit analysis for sealing between two mating surfaces.
Update Gasket Elements
Use the Entity Editor to update gasket elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
