Create Rod Elements
Use the Rods tool to create 1D rod elements.
A rod element is an element created in a space between two nodes of a model where rod properties are desired. The two nodes are related to each other based on the properties of the rod element connecting them.
Update Rod Elements
Use the Entity Editor to update rod 1D elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
