Create Surface Elements
Use the Surfaces tool to create 1D surface elements.
Surface elements may be used for various load and surface effect applications.
Surface elements are defined by two to five node points and by the material properties. The nodes for this element must share the nodes of the underlying solid elements.
Update Surface Elements
Use the Entity Editor to update surface elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
