Create Pretension Elements
Use the Pretensions tool to create 1D pretension elements.
Pretension elements are used to define a 1D pretension section within a meshed structure.
The structure can be build from any 2D or 3D structural elements (solid, beam, shell, pipe, or link).
Update Pretension Elements
Use the Entity Editor to update pretension elements for the desired keyword.
This includes modifying the assigned nodes, property, orientation, and so on where applicable for the solver.
