Create Axisymmetric Elements
Use the Axisymmetrics tool to create axisymmetric 1D elements.
Axisymmetric elements are two-node elements with three degrees of freedom at each node: translations in the x, and y directions, and rotation about the z-axis.
Update Axisymmetric Elements
Use the Entity Editor to update axisymmetric elements for the desired keyword.
This includes modifying the assigned nodes, property, and so on where applicable for the solver.
