*analysis()
Creates an analysis in HMASCII format.
*analysis (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the analysis.
- name
- The name of the analysis.
- color
- The color of the analysis. Valid values are 1-64.
*analysis(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
