*axisymmetries()
Creates an axisymmetry in HMASCII format.
*axisymmetries (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the axisymmetry.
- name
- The name of the axisymmetry.
- color
- The color of the axisymmetry. Valid values are 1-64.
To create an axisymmetry with ID 100, name "my-entity", and color 1:
*axisymmetries(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022.1
