*membersections()
Creates a membersection in HMASCII format.
*membersections (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the membersection.
- name
- The name of the membersection.
- color
- The color of the membersection. Valid values are 1-64.
To create a membersection with ID 100, name "my-entity", and color 1:
*membersections(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
