*constraint()
*constraint (id type locationid inputsystemid comp1 comp2 comp3 comp4 comp5 comp6)
HyperMesh HMASCII Command
- id
- The ID of the load (must be unique).
- type
- The type of the load.
- locationid
- The node ID where the load is applied (must be a valid node).
- inputsystemid
- The reference coordinate system of the load (must be a valid system or 0).
- comp1
- The value of the constraint in dof1 (-999999.0 for none).
- comp2
- The value of the constraint in dof2 (-999999.0 for none).
- comp3
- The value of the constraint in dof3 (-999999.0 for none).
- comp4
- The value of the constraint in dof4 (-999999.0 for none).
- comp5
- The value of the constraint in dof5 (-999999.0 for none).
- comp6
- The value of the constraint in dof6 (-999999.0 for none).
Constraint definitions must follow a *loadcollector() command.
None.
