*mechanismconstraints()
Creates a mechanism constraint in HMASCII format.
*mechanismconstraints (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the constraint.
- name
- The name of the constraint.
- color
- The color of the constraint. Valid values are 1-64.
To create a mechanism constraint with ID 100, name "my-entity", and color 1:
*mechanismconstraints(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
14.0.120
