*geometricrepresentations()
Creates a geometricrepresentation in HMASCII format.
*geometricrepresentations (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the geometricrepresentation.
- name
- The name of the geometricrepresentation.
- color
- The color of the geometricrepresentation. Valid values are 1-64.
*geometricrepresentations(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021
