*integrationrules()
Creates integrationrules in HMASCII format.
*integrationrules (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the integrationrules.
- name
- The name of the integrationrules.
- color
- The color of the integrationrules. Valid values are 1-64.
To create integrationrules with ID 100, name "my-entity", and color 1:
*integrationrules(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
