*rigidwallgeometry()
Adds geometry to a rigid wall group in HMASCII format.
*rigidwallgeometry (id geometrytype ....)
HyperMesh HMASCII Command
- id
- The ID of the group.
- geometrytype
- 1 - infinite plane
- 2 - finite plane
- 3 - infinite prism
- 4 - finite prism
- 5 - cylinder
- 6 - sphere
- For geometrytypes 1 and 2:
- xaxisx, xaxisy, xaxisz
- The x, y, z components describing the local x axis.
- lengthx, lengthy
- The local x and y length of the rigid wall.
- For geometrytypes 3 and 4:
- lengthx,lengthy,lengthz
- The local x, y and z length of the rigid wall.
- For geometrytype 5:
- radius
- The radius of the rigid wall.
- lengthz
- The length of the cylinder.
- For geometrytype 6:
- radius
- The radius of the sphere.
- For geomtrytypes 7 and 8:
- MADYMOID
- ID corresponding to the geometry description in the MADYMO deck.
None.
