*valuesforentity()
Defines a data names block for new-style HyperMesh entities in HMASCII format.
*valuesforentity (entity_type,entity_id,number_of_values)
HyperMesh HMASCII Command
- entity_type
- The type of entity for which the data names are being defined. Only new-style entities are supported.
- id
- The ID of the entity for which the data names are being defined.
- number_of_values
- The number of data names that follow.
To create a region with ID 100, name "my-entity", and color 1, of config 1 and topo 22:
*regions(100,"my-entity",1)
*valuesforentity(regions,1,2)
*valueunsignedint("config",1)
*valueunsignedint("topo",22)
Incorrect usage results in an import error.
Version History
14.0
