*joint_spherical()
*joint_spherical() (id type node1 node2 propertyid orientation orientid1 orientid2)
HyperMesh HMASCII Command
- id
- ID of the element.
- type
- Type of the element.
- node[1,2]
- The node IDs of the element.
- propertyid
- The ID of the element’s property.
- orientation
- The orientation associated with the element. Use:
- 0
- None
- 1
- Systems
- 2
- Nodes
- orientid[1,2]
- The system or node IDs associated with the element.
This command must follow a *component() command.
None.
