*clearances()
Creates a clearance in HMASCII format.
*clearances (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
- id
- The ID of the clearance.
- name
- The name of the clearance.
- color
- The color of the clearance. Valid values are 1-64.
To create a clearance with ID 100, name "my-entity", and color 1:
*clearances(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.2
