*memberpanels()
Creates a memberpanel in HMASCII format.
*memberpanels (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the memberpanel.
name
The name of the memberpanel.
color
The color of the memberpanel. Valid values are 1-64.
To create a memberpanel with ID 100, name "my-entity", and color 1:
*memberpanels(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022
