*materialbehaviors()
Creates a material behavior in HMASCII format.
*materialbehaviors (id,name,color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the material behavior.
name
The name of the material behavior.
color
The color of the material behavior. Valid values are 1-64.
To create a material behavior with ID 100, name "my-entity", and color 1:
*materialbehaviors(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2022.1
